Shop Our Other Throttle Parts
Shop All Our Parts
Throttle Assembly Springs Set
Go Kart and Mini Bike Throttle Connectors
This kit helps you connect your throttle cable up to your engine's throttle system. And the high quality springs ensures that your go-kart gas pedal springs back up when released.
Kits includes a throttle return spring, spring anchor, 2 cable stops, cable retainer and a hold-down screw. Order cable separately. Fits most go karts.
110% Lowest Price Guaranteed!
If you're rehabbing an engine, you'll most definitely need a spring kit for hooking up the throttle. Many old engines have their governor parts in disrepair, and that's usually where the cables hook up.
Also, if you're disconnecting the governor, you may be forced to be creative when you re route the gas cable.
